The engine runs perfect at idle and at high to full speeds but has major hesitation and rough running getting from idle towards planning speeds. I need to go back and forth with the throttle to get up on plane. had all 3 carbs replaced about 4 years ago due to the effects of alcohol/gas . Been running alcohol free gas since. This summer I have replaced the fuel hose / primer bulb, fuel filter, fuel pump, and checked the fuel lines. All 3 cylinders show around 105 psi. Thanks for any input as I don't want to replace this outboard
