Any help appreciated.......
Trim/Tilt will not move up or down or even click. So I bypassed relays and put 12V on green and then blue wires but not a gig. Wired straight from motor case to negative on battery so think ground is ok.
I manually raised the engine using release valve and I noticed one of the two small piston rods is stuck down, other is up. Is this normal? Is it jammed?
Can I take off motor without bleeding the system?
Thanks in advance
Pat
Thanks in advance
Pat
