1999 115hp evinrude ficht
Cshaw
Hey guys I recently bought an outboard motor a 115hp evinrude year 1999
E115fpleen
Having an issue with no crank at the key switch when I bought the motor it supposedly had a bad number 4 injector well the fuse was blown for 2&4 injectors I bought the correct key switch to the motor have it hooked up turn key on can hear fuel pump priming but no start any help would be great I believe the emm is ok I’m able to communicate with it through the evdiag and at first when I installed the key switch it would blow the fuse
So please help I’m sure it’s a simple problem but can’t find it thanks
Do I need to hook anything else to to the motor all I’ve hooked up is the ev diag tool and the key switch nothing else just need it to turn over before I hook up oil and fuel
I’ve checked all fuses and relays that pertain to the ignition
