Hello
I've been having some problems with my grandfathers old 1998 Mercury 20E 2-stroke, It starts very easy and runs great at idle and low speed but when I push the throttle it will start acting up and cutting out, but strangely I have gotten it to run well full throttle a couple of times for extended sessions after restarts...
At a certain throttle it will become almost like a pendulum, going up in rpm then cutting out and falling down then up again repeating.
The problems started when I started it up a couple weeks back, it was running very bad (kind of the same problem but it cut out right away) and when I opened it up I found the "idle-wire" completely loose inside, I reattached it but I'm not completely sure it's correct since I can't find any instructions (I connected it by twisting it inside a rectangular hole on the arm connecting to the control lever) anyhow it seems right but the idle-wire is kind of loose.
I also went over the fuel line and changed the bladder etc. but everything there seems fine (it does not react to pumping the bladder when acting up)
Here's a video of it running: https://youtu.be/VciXR2RL61A?list=UUzBwqB1NIf6xZzmEW_QVydA
Last year I also had a guy clean the carburetor with ultrasound and used a kit to replace what needed replacing along with fuel filter etc. and It ran great after that.
(It does not run any better with the choke out but rather cuts out as expected.)
So I'm not sure what to do, My limited experience tells me I would have to go trough the carburetor again but I wanted to see if someone has any better suggestions...?
