jamwellman
Hello all,
I was hesitant to make a post but after a month of trial and error and not finding my exact problem or solution on forums I decided to give it a shot. I will try to keep it as brief as possible so apologies if it's long winded. I want to provide as much info as possible.
When buying the boat, the previous owner started it instantly and it ran for several minutes (on muffs) so I thought it's all good, here's some money. The gas tank was practically empty FYI.
A few days later I put 50:1 and some stabil 360 in it. Premium no ethanol. Got it on the water and it started right up no problem. I got 5 minutes of cruising and WOT and it choked out and died on me. It started right up again and I got another 5 out of it before it did the same thing. Started up no problem but now when I put it in gear, it bogs down like it's misfiring or only running on 2 cylinders. I initially thought maybe it was running in SLOW mode but based off of reading and watching some videos of SLOW mode, I don't believe that is the issue. This is running much rougher than the SLOW videos I found. Like most people it runs great in the driveway and bogs down when on the lake. It spits water like a champ at all times so I don't think it's a water pump/heat issue though I have a rebuild kit in case. I've checked the bulb when this is happening and it's tight. Engine will not rev up when this is happening.
Batteries are good and less than 2 years old.
When running good on the driveway I started pulling wires to the coil from power pack. Cylinders 1 and 3 showed a change but cylinder 2 did not. Guess my problem is in cylinder 2 then. Here's what I've done so far:
Used a clean external fuel tank with different lines and different gas....same problem.
New fuel lines from tank to motor along with new connectors and new fuel filter.
Cleaned and rebuilt all 3 carbs with new rebuild kits...they were surprisingly clean. I did notice the main emulsifier jet on top carb was a LITTLE bent from center thought it was still open so able to suck fuel i'm guessing. The low speed screws are 7 turns out which seems like a lot to me.
New spark plugs and wires
Checked compression with an OLD unit and all 3 cylinders were right at 90.
Tested coils and all were in range but a mechanic told me that coils can and do fail under load. Put in a new coil and got another 10 minutes out of it before the problem came back
Have not taken the fuel pumps apart but that is next on the list. I have rebuild kits for those on their way.
Haven't checked timing but will also do that. The fact I've gotten it running well on the water a few times makes me think it's not timing.
Could it be a bad power pack causing cylinder 2 to misfire?
I'm going to test the fuel in the fuel tank with some putty that turns purple if there is water in the fuel.
So.....what are your thoughts and what am I missing? Any help is appreciated and if pictures or a video would help, I'm sure I can figure out how to make that happen. If it's not obvious, I am far from a mechanic and electrical problems are over my head at this point.
Thanks all.
Thanks all.
