"Hi, I will try to cut this p
"Hi, I will try to cut this post short,
Model # E175EXECD
When priming the bulb fuel is comming out of the top vent line that incerts into the baffle. the primer bulb never get hard. The vent line is attached to the top of the vapor pump , that is attached to the vapor seperator chamber.
My first guess is that the needle and seat are worn in the chamber. I am assuming that when fuel is primed in the chamber the float closes the chamber and forces the fuel out to the carbs? If the float does not close will this push the fuel out the vapor pump? I do not think solid fuel shoud be getting into this pump and if it has do you thing it is damaged?
Any help here.... thanks so much..."
Model # E175EXECD
