E115GLECM. New to me boat. VRO needed to be replaced (seller had been running premix), so I had my mechanic do that with a brand new kit. First time taking the boat out to do a test run after mechanic installed the VRO, it started easily, had a slow hole shot, would not creep over 4300 RPMs on the tach at WOT, and topped out at around 36 mph on my gps. This was a relatively light load, just my wife and I, a full tank of gas, and no cooler, fishing gear, dogs, etc. I inspected the exhaust port on the engine, and it was caked with what looked to be carbon buildup which I thought to indicate the engine was overpropped and lugging. Propeller was a 14x19, so I swapped it for a 13 pitch at the recommendation of a local propeller guy.
Next time I ran the boat, 2 guys, loaded with a cooler, full tank of gas, fishing gear, its hole shot was GREATLY improved, however, other than an initial jump to 5500 on the first rev when laying the throttle down, it reduces back to 5100 RPMS at WOT. Top speed is roughly 31 mph with the 13 pitch. I still feel like I am leaving RPMs on the table. I boat in freshwater at about 3,000 feet over sea level. I also noticed that, while idle seems to be smooth, the engine seems quite rough at real low forward speeds.
Is this what I should expect?
~2,177 lbs
The engine has good compression, new spark plugs. Seller stated he had just had new carbs put in. I am going to replace the fuel filter. Fuel lines appear fine, but I'm not super knowledgeable with outboard or marine repair in general, and this is my first outboard. I am also considering removing and cleaning the carbs thoroughly, but hesitate considering they were apparently just replaced earlier this season.
Am I overthinking this? For an engine that is rated for WOT from 5k-6k, I am "just there", but I would have thought dropping from a 19 to a 13 pitch would have been more dramatic RPM-wise. The condition of the 19 pitch was pretty poor, and makes me wonder if it was the original prop that was outfitted on the boat in 1998 -- can anyone here speak to this? Alumacraft customer service has not been helpful. If that is the case, and this boat was designed to be pushed by a 19 pitch, I am not sure where I should begin to troubleshoot the engine's performance.
I have a factory service manual and a seloc manual.
Thoughts?
- Boat is a 1998 Alumacraft Trophy Sport 175 ~ 1100 lbs
- Engine weighs 319 lbs
- Kicker weighs 108 lbs
- Fuel @ 23 gallons ~ 200 lbs
- Gear ~ 50 lbs
- Guys ~ 400 lbs
~2,177 lbs
Thoughts?
