Greetings,
As the subject line says, I have a 1998 BF 90 that came on a boat I recently purchased. Based on the condition of the spare props that came with the boat, I suspect that the previous users hit some rocks while piloting in shallow waters.
I have used the boat quite a bit this summer, and all was well until a couple of days ago. The motor had been shifting fine, but all of a sudden would not go into reverse. Forward and neutral still work fine however. I checked the shift and throttle cables at the motor, and then detached the cables at the motor and tried to shift into reverse while a helper rotated the prop. I can see the shift rod rotate into position, but the prop will not rotate.
I then checked the gear case oil drain plug and found metal powder and one metal chunk about the size of a grain of rice. At this point I am guessing that either the clutch dog or teeth from one of the gears has sheared off. I am not very familiar with the innards of the gearcase, so perhaps the metal I saw is from some other component?
The questions I have are: 1) Am I on the right track, or
missing something here? 2) If I decide to rebuild te lower unit, where is a good place to purchase parts? 3) How technical is rebuilding the gearcase? I know that is a subjective question, but...... 4) Would I be better off buying a Honda lower unit and putting it onto this motor? I believe I can do that with a new shift rod and some other new parts.
Thanks in in advance for any replies. Hoping to get back on the water soon!
-Ryan
-Ryan
