I have a 1998 BF 130A. This engine runs fine both at idle and cruising.
If you shut it off after use and try to start it 15-20 minutes later it will turn over but will not start. If you wait long enough for it to cool down it will start ok
Engine light comes on for 2 seconds
High pressure fuel pump runs and shuts off. Light goes out.
Checked trouble codes- none
Changed relay- same problem
Grounded LG/R wire to make pump run all the time with key on -no help
Checked spark with timing light - it's ok
Checked vapor seperator- it's ok
Let engine cool down- starts ok
I need help
I need help
