Raw water cooled salt water use new impellar in the spring. always ran cool but today it started to overheat. Cooled down restarted w/ same result. It had good water flow in the T-stat housing, the belt is tight, the circulating pump seems good ( no leaks or woobles) It will idle at 175 & stay there but at 3000 rpm's the temp shoots up. The risers & manifolds are original. I am going to check the PS cooler & the exhast flaps, hoses & T-stat but if I do need new risers & manifold where is the best place to buy them? Any brands too avoid
All suggestion welcome. TIA
