1998 200 Oceanpro eng check lt.
interd0g
Hi - My engine died out at sea with fuel starvation . The eng check lt came on.
The harbor entrance leads to the open Atlantic so this is not a good thing.
When I got back I checked the fuel suction pipe an the mesh filter, the pipes , anti siphon, replaced the main filter/separator and the one under the hood but the engine still showed a light intermittently and tended to die out. The primer bulb remains normal.
I then noticed fuel flowing out the top of the primer solenoid. The red plastic valve shaft was split.
I bodged that up and the engine tests good up to full load at sea no leak.
But I still get an intermittent eng light. Any ideas?
If the tank is below the mtr you can knock the ball,spring and cap out of it with a long skinny punch. Then try it. They have a habit of sticking.
