1997 Ocean Pro 150hp Clutch Dog question
nick83
Hi everybody all the way from Australia.
I have a 150hp Ocean Pro here that has a symptom that is consistent with a worn clutch dog. The boat will make a loud bang sound and jerk as if it had hit a log or something and the force of it feels quite violent. Happens randomly but mostly at cruising speed. Last time out on the water I noticed the loud bang sound was happening more frequently and at one stage I nearly fell off my chair!
Now the question guys is that when I checked the drain plug for metal shavings/particles, there wasn't any..
So can it still be a worn clutch dog??
Thanks guys any help really appreciated..
Thanks mate I'll get someone to check these out asap.
Normally would a worn dog drop metal shavings though? I would love to rule out the gearcase.
(Centering Shift Cable)
(J. Reeves)
When all is as it should be, the proper method to adjust the shift cable is to disconnect the cable from the engine. Move the shift linkage on the engine to find the center of the play in neutral, and when found, leave it centered.
Now, grab the end of the shift cable sleeve, push and pull it to find the center of the play there, and center that play.
Adjust the trunion on the threaded portion of the shift cable so that the centered play of the cable lines up with the centered play of the engine's shift linkage. Install and lock the shift cable with the retaining clamp in that position. That's it.
(Jumping Out Of Gear - Manual Type)
(J. Reeves)
This pertains to lower units on all OMC manual shift outboard engines, or any OMC engine with lower units defined as a Shift Assist or a Hydro Electric Shift unit which incorporates a "Shifter Clutch Dog".
Within the lower unit, splined to the prop shaft is what is most often referred to as a clutch dog, hereafter simply called dog. The dog has at least two lobes protruding from it on both ends, facing both forward and reverse gear. The forward and reverse gears also have lobes built into them near their center area. When the engine is running, in neutral, the gears are spinning constantly via the driveshaft being connected directly to the powerhead crankshaft, but the propeller does not turn due to the fact that the dog is centered between the two gears, and the dog lobes are not touching either of the gear lobes.
When the unit is put into either gear, shift linkages force the dog (and its lobes of course) to engage the lobes of the gear. The lobes of the spinning gear grab the lobes of the dog, and since the dog is splined to the prop shaft, the propeller turns.
The lobes of the dog and gears are precisely machined, most with right angled edges that could be installed in either direction, and some with angles slightly varied that must be installed in one direction only (one end only must face the propeller). Dogs that can be installed in one direction only, if reversed, even if the dog and both gears were new.... would jump out of gear almost immediately. Keep in mind that the lobes are precisely machined with sharp angles!
Due to improper adjustment or worn shift linkages, but usually due to improper slow shifting, those precisely machined sharp edges of the lobes become slightly rounded. Now, with those lobes rounded, as the rpms increase, the pressure of the gear lobes upon the dog lobes increases to a point whereas they are forced apart (jumping out of gear), and due (usually) to the shift cable keeping tension on the engines shift linkages..... the unit is forced back into gear giving one the sensation that the engine has hit something, and the cycle continues.
Some boaters with manual shift engines have the mistaken belief that shifting slowly is taking it easy on all of the shifting components..... Wrong! Shifting slowly allows those precisely machined sharp edges of the dog and gears to click, clank, bang, slam against each other many times before they are finally forced into alignment with each other..... and this is what rounds those edges off! The proper way to shift is to snap the unit into gear as quickly as possible.
Thanks Joe so if the lobes round off would there be metal shavings evident on the drain plug still?
Usually one would see something mixed in with the gearlube but not always as the metal shaved off the dog and gear would be so minute and gradual that it would be almost microscopic... UNLESS... a good size piece chipped off. Be assured that the rounding off of those lobes is what's taking place, due to either slow shifting, misadjusted cable, or having someone change the height of the shift rod if the lower unit was off for any reason.
Hey guys it ended up being the Power Pack. Issue now resolved. If anyone experiencing similar issues be sure to get the PP checked first cheers all.
