Hi all,
Last weekend I purchased my first boat. It is a 97 Stratos 268FS, with a 97 Johnson 115hp V4 (mod. J115TSLEUAhttp://www.boats.net/parts/search/BRP/JOHNSON/1997/parts.html). I am having trouble with the tachometer and the trim indicators on the dash.
The trim indicator works fine until I start the motor, then the needle goes all the way up as soon as the motor starts running.
On the tachometer, with everything off, the needle is in the "red zone", when the ignition is turned on it goes to zero, and after starting the motor it does not register any rpm, just hangs between 0 and whatever the top digits are (at around 6 o'clock position). First time I had the boat on the water, it seemed to work just fine. Checked the wiring at the power strip and the gray wire is connected to the yellow/gray wire from the rectifier (which has a red, yellow, and yellow/gray wires).
All gauges are manufactured by Faria, I am assuming all are original to the boat.
Any insight is welcome - I really want to make this boat perfect ))
