"This boat is a 1997 bryant wi
"This boat is a 1997 bryant with a 4.3 mercruiser. carburated, alpha
Today we took our boat out want to do some sight seeing in the fall being the 1st year owning a boat. Hoping to get to go out a few more times before storing it for the winter. All summer long this boat has had a starting problem. Hard cold starts. We normally take it out every other weekend. Can't figure the exact problem out but here's what I do to get it running. With help from another person. While they crank it and having the shifter in foward position, just a little throttle, I slowly pore gas in the carb, I'll some times manually mess with the choke. Which I think sees to help. Nomally between 5 and 30 minutes I have the boat running fine ready to go out. This is the first problem
Today when getting the boat ready. I did my normally routine. I noticed one thing different. I think I may have poured too much gas in because I had a back fire. Didn't pay it too much attention. Once it started seemed to miss alittle but clear up. So we headed for the water.( btw I use the host attachment for a water supply before going to the water). Once we get the boat in the water we head out. Running about 2000 rmp's for about 10 minute I start to increase the throttle. I realized that the more thottle i gave it that the rmps wouldn't increase and the boat wouldn't speed up. We had family in from up north, didn't want to upset them but I told my wife that we may have a problem. Wait and behold within another 5 minutes the warning beeper went off and the engine was up to close 180 to 200 f. I quickly turned off the engine. Then engine was hot and I don't think there was any water in any of the hoses when I was checking. A nice guy pulled us back to our trailer. Once there I trailered the boat and the temp was back down to 125. When I got home tonight I check the hoses and there was water in them. Not sure the best place to begin trouble shooting or what to try. I have the seloc stern drive manual and will be reading there also.
Other advice I need to know is storing this for the winter. I just checked the weather channel and they are predicting monday tue and wednesday to get below 32 degrees. I think 28 will be the coldest. If you want to check Our zip is 37323. will it be ok if I haven't winterized it yet or do I need to get bus? Not sure so what I have done was I removed some of the water plugs for about 30 minutes then put them back. A problem there is that I only found 4 and I was told there was five. I found 2 on each side of the engine. 2 on the block, 2 on the hose ends. Where would that 5th one be? I would like to get all these problems fixed before taking it back out on the water. or at least by next spring.
Sorry to be so lengthy just want to give as much info as possible. If you need more just let me know thanks be blessed Tracy"
