I fished on Sunday and the boat ran well. I had no complaints at all. Went out Monday morning to flush the motor and it would not idle right. Start it up, it would idle at 1400-1500 RPM then drop down to it's normal 1100-1200 when Quick Start dropped out. After 5-10 seconds, it would jump back up to 1400-1500 rpm and stay there for 15-20 seconds then drop back to 1100-1200 rpm again. Sometimes it will would miss right before the transition from high to low idle, sometimes not.
All fuel connections are tight. Primer bulb stays relatively hard. The Racor fuel filter is fairly new. Maybe 300 gallons of fuel run thru it. The bouncing back and forth between “quick start” speed and idle speed has me thinking it’s electric, not a fuel problem
FWIW: This motor had never idled reliability below 850 RPM. Anything lower than 850 rpm and its hit and miss if it will stay running for any length of time.
