Both carbs were full of oil. The pontoon boats gas tank has a check valve going into the stem that goes in the tank. Works but why do I need it when I have a squeeze bulb? I siphoned the tank with the check valve out and it siphoned quickly so I guess I can assume any inline in the tank filter cant be plugged. The gas lines need replacing they are hard and missing clamps. When I do all that and hook up the VRO should be ok right? If not run Pre Mix by pass VRO?
