1996 suzuki 115 EFI engine cuts off when giving throttle to plain off
N
nealr2
Guest
"Engine runs a little rough at
"Engine runs a little rough at idle, when i give it throttle to take off and plain it cuts off,but starts right back up\no problem. I've checked plugs, fuel, fuel pressure, fuel lines, compression,;fire on all cylinders. I'm thinking it may be some kind of sensor problem. Does anyone have an idea of what may be causing this?"
"Idle air control valve? Don&
"Idle air control valve? Don't know, but sometimes on Honda's it helps if you remove this valve and clean out the gunk in it. On a Honda it is easy to get to - a 5 minute operation."
