wildcatmarineandsmallengi
I have cleaned and put new kits in carbs, installed new 2 stage fuel pump (non-VRO). Has a new fuel line with primer bulb. Tried running off portable tank. Check timing. did a complete sync and link. Has a new fuel filter. New spark Plugs. Spark test shows good spark on all 4 cylinders. This thing is kicking my butt, and I am running out of ideas as to why it will not come up on a plane while accelerating. I have looked for loose hoses, put a new primer solenoid kit on it, and nothing seems to fix the problem. Gas is new, engine is mounted properly at the correct height. hub in prop is good, it just will not gain RPM's after about 2500. Any Suggestions will be greatly appreciated. Compression on all 4 cylinders is 120-125.
