westcoastdonni
"1995 Yamaha 9.9HP High Thrust
"1995 Yamaha 9.9HP High Thrust Long Shaft Outboard
Well its summer but the snowball keeps rolling around here. What started off as an impeller replacement has turned into a complete nightmare.
I started off by struggling to no end to get the gear case off and finally found the solution by heating the 4 bolts that hold the gear case and knocking out the corrosion enough for the lower unit to come free.
With the lower leg free, I then removed the four bolts holding the top of the water pump on and that came free without to much trouble. Of course the impeller was fine so I popped on a new gasket and tightened up the four bolts. Only on the last one did I tighten it just a little to much and I felt it weaken and snap.
So I drilled a hole in the bolt and tried to use a broken bolt extractor to remove it. Of course that broke in the broken bolt.
Thinking I may be able to get at the bolt if I remove the seal housing below the water pump, I began prying off the seal housing (as stated in the clymer manual)and it actually separated.
Now I have the seal housing free but the drive shaft is stopping it from sliding off.
So my question is, do I have to remove the drive shaft to get the seal housing off or is there another approach with the seals in the housing - my clymer manual doesnt say? If it turns out that the drive shaft has to be removed wich looks complicated and requires special tools, is this something I want to do or should I just lower my head in shame and take it to a dealer?
Thanks in advance for any help."
