1995 mercury 75hp. I replaced the thermostat, poppet diaphram, and gasket.
I had broke off one of the bolts to the thermostat housing so I drilled it out.
When I drilled it out the bolt, I drilled too deep before I could stop the drill motor.
So I removed the exhaust plate and baffle to see the damage( which took me two weeks of tapping on bolts to break them loose).
turns out it just drilled into the bottom of a bolt hole for the exhaust plate.
now after replacing the gaskets and bolts and going to work it has been about 3 weeks or more,
The battery was too dead to turn over motor to crank it and would not charge good enough to crank it
after I put it all back together.
Then I bought a new battery and motor dont even want to turn.
I can here a click like a starter relay but thats all it does, the starter aint even trying. What
may could have happened? What wires should I investigate? Everything looks to be tight
