Lenny 1250
Hello everyone, I am a newby to this forum and I need help before I go crazy. First and foremost I am not a mechanic and don't claim to be one, but I do most of my own repairs on my own stuff when something breaks down, so I have a little bit of knowledge. This though has got me buffaloed. I have a neighbor that used to be a boat mechanic back in the day, but his skills are diminishing due to his health. As described above I have no spark on cylinders 1 and 3. The model number is J60TLEOC. Here's what has been done so far,
Compression test - all 3 cylinders tested at 130
New battery - fully charged
New starter
New timer base (trigger)
New power pack (ignition coil)
New spark plugs and wires
I have a manual and based on the test it says to run (using an ohmn meter, because I don't have any special meters) everything pointed to the power pack according to my neighbor and myself as well. I also have a friend that is a mechanic and he too thought it would be the power pack. The power pack replacement came in today and I installed it and when I checked spark it now has fire to #1 and #2 but still nothing on number 3. All of the coils check out fine as well as all grounds. The only things that haven't been replaced is the stator and the rectifier,. I have tested the stator numerous times according to the manual and it reads as it should. I have not tested it with a volt meter while turning it over. Could it be possible that the stator is not putting out enough current to fire all cylinders? Would the rectifier have anything to do with it not firing on all 3? Any help or suggestions on what to check would be greatly appreciated. Just don't know what else to look at!
New starter
