I have a 1995 Johnson 30 HP 2 stroke outboard on my Princecraft. This year it developed a problem that I have yet been able to fix. It runs perfectly fine for about 5 minutes, but then suddenly starts surging hard. If I leave it in neutral, no matter what percent of throttle I give it, it doesn't do this, but as soon as I put it in gear it starts surging. It’s hardly noticeable under a 1/4 throttle, as I get into the throttle more it gets worse. At full throttle it surges hard, and if forced to continue, will start to loose power until it dies. Under 1/4 throttle, I can drive it around and keep going with only a slight surge that does not kill the engine. Thinking it was overheating and this was some sort of limp mode, I replaced the water pump, thermostat, and water temp sensor which did not fix it. So I also replaced all the fuel lines, gas tank seals, primer bulb, and fuel pump. Nothing seems to have fixed it. Pumping the bulb does not change the surging either. The hard part is troubleshooting it. I can’t get it to duplicate the actions in my driveway, it has to be in the water, and has to get complete warmed up before it will do it. This poses a challenge to getting it narrowed down. Also, no warning alarms or bells are sounding.
Any suggestions on what to focus on next or how to resolve this issue?
TIA.
TIA.
