1995 Evinrude Vindicator 200HP
B
billyg
Guest
" Joe,
In followup to your c
" Joe,
In followup to your comments on oil injection malfunction, disconnecting the oil injection and going to PRE-MIX solves that problem, right? I ask this because of my limited resources for repair, and also thinking PREMIX as removal of FUTURE PROBLEMS! Also, is it as simple as your description makes it sound?
I would appreciate your thoughts on this, and as always....thank you VERY MUCH!
Bill "
"Bill.... You ask: "Also,
"Bill.... You ask: "Also, is it as simple as your description makes it sound?"
I'm not sure of what you speak, but if you're refering to my past posts of how to eliminate the VRO system, yes it's that simple. And a copy of that procedure follows.
(VRO Pump Conversion To Straight Fuel Pump)
You can convert the VRO pump into a straight fuel pump, eliminating the oil tank and VRO pump warning system, but retain the overheat warning setup by doing the following:
1 - Cut and plug the oil line at the engine so that the oil side of the VRO pump will not draw air into its system. Trace the wires from the back of the VRO to its rubber plug (electrical plug) and disconnect it.
2 - Trace the two wires from the oil tank to the engine, disconnect those two wires, then remove them and the oil tank.
3 - Mix the 50/1 oil in the proper amount with whatever quanity fuel you have. Disconnect the fuel line at the engine. Pump the fuel primer bulb until fuel exits that hose with the tint of whatever oil you used. Reconnect the fuel hose.
That's it. If you want to test the heat warning system to ease your mind, have the key in the on position, then ground out the tan heat sensor wire that you'll find protruding from the cylinder head. The warning horn should sound off.
Joe
