jessebradley
"Model# E25TEEOR, The problem
"Model# E25TEEOR, The problem description is upon initial startup engine idles fine and runs with no problems...after running at cruise speed for approx 10-15 min engine looses all power and stutters uncontrollably, engine doesn't stall, or die out in neutral when reving to 1/4 throttle, normally I can let it sit at idle in neutral and then go again in most cases. Last night while running it.. it got to the point where it would stall when the problem presented itself. Fix actions taken so far I've rebuilt the carb, swapped plugs from NGK back to Champion. I'm at a loss any advice given would be greatly appreciated."
