Hi all,
My 1995 90hp Mercury 3 cilinder has a rough idle. It runs really good at higher speeds but not at idle.
I therefore am trying to adjust the idle mixture screws to a proper setting. My service manual instructs me to initially set these screws at the following setting. Top carb 1/2 turn out, bottom carb 1-1/4 turn out and bottom carb also 1-1/4 turn out. The motor will start at this setting but with these initial setting. The manual says that you have to screw in the screws until the outboard stalls/surges and then back out 1/4 of a turn. But if the top screw is only a 1/2 turn out there isn’t much room for adjustment. So my question is, should I leave the top carburetor at the 1/2 turn out and adjust the other two, or maybe start with a different initial setting?
All advice is welcome, because this is the first carburetor idle adjustment for me.
Also I included some snapshots of my service manual.
Thanks in advance!
Thanks in advance!
