I'm trying out a virtually unused 94 Johnson 50 (owners Dad died the day after he bought it). No spark on either cylinder.
I separated the cannon plug for the external harness to isolate the external wiring harness and kill circuit and jumped the engine to crank the starter; still no spark but I did prove the kill circuit to be correct.
Then we undertook to troubleshoot per the CDI instructions for the armature and power pack and in the process removed the connectors to all only to find them good (at least as good as could be determined without a DVA meter).
Then just out of curiosity, I tried it again and the danged thing worked with nice blue spark that almost blew my finger off. Many restarts and extended running on the muffs with no problem. That was in October and I had to chalk it up to Halloween - I HATE voodoo problems that solve themselves.
I finally got around to taking the boat to the water today and once again no spark. I'm baffled. VOODOO HAS RETURNED.
I read on one CDI troubleshooting guides that if the rectifier had been disconnected then reconnected and the system worked that the problem would likely be the rectifier. That of course is what occured during the first troubleshooting done. I wonder if the rectifier could be the problem
Also, having heard that powerpacks often exhibit intermittend failure modes, I'm looking for a pack for the engine just in case but I'm having trouble identifying the right part number for a power pack for this engine.
The BRP site lists two possibles... I surmise one is for engines with SLOW the other for those not having SLOW.
Under my model number J50TLERE is one listed for the Electric Start 40 - 50 EL and TL models as part number 0175316.
Under model number J50TLERE is one listed for the Electric Start and TL models only as part number 0585074.
Anyone know which one is correct or how one determines the correct part number?
Steve
Steve
