ya i pressed the enrichment button a little to see if it would pick up but started to bog. did not do kill wire, yes i will have to get my cdi electronics book out and do dva testing, what are the 2 coils on stator i thought 1 was low and 1 high?Have you tried pumping the primer ball when that happens? Disconnect the kill switch? Run with a timing light to see which cylinder is missing. Go to www.cdielectronics.com for.the guide.to test your ignition. No high speed windings in your stator.
Not the primer the bulb in the hose. If you have electric start there is a set of charging coils under the flywheel. If not.you have a driver and a pickup coil.ya i pressed the enrichment button a little to see if it would pick up but started to bog. did not do kill wire, yes i will have to get my cdi electronics book out and do dva testing, what are the 2 coils on stator i thought 1 was low and 1 high?
