Troutcatcher
Looking for some assistance. I have a 175HP oceanrunner and it will not go past 2500 RPM on load. When you run the motor out of gear you can achieve full RPM. I had the motor completely serviced including the water pump, rebuilt all six carbs, changed oil in lower unit back in April. Have used the boat several times since the service. Two weeks ago took the boat out and initially it ran normal. I was trolling and when I went to move to another location the boat would not get past 2500 RPM. I have verified all of the throttle linkage is connected and all carbs function properly. I have disconnected the temp sensors and nothing changed. This occurs from a cold start under load. I put new plugs in the boat and nothing changed. the motor is not getting hot but this happening as soon as the engine starts. Engine starts fine, new fuel filters, new priming bulb. I am a maintenance intensive person. I am at a loss of where to go next and looking for some advise.
I appreciate any help.
Jeff
Jeff
