J
jordan holmes
Guest
would disconnecting the 5 pin
would disconnecting the 5 pin connector going to the powerpack disconnect all of these things in one step? and the timing wheel does have a hairline crack in it. i ordered a new one. just had the wires replaced to omc resistor wires and the correct plugs. this was done before last run and no change. also if disconnecting the 5 pin connector disconnects all of the things you said to then i have run it once before with all of this not connected. and still does same ole thing. runs great when cold and once it gets hot if i am at full throttle it is almost like it bogs out and when i crank back up it wants to buck and jerk. if i keep trying to crank it it will idle some but generally it surges from 1200 rpm up to 2000 sometimes and if put in gear it just bucks and dies. if at this point you check fire you can flip a coin sometimes you have fire and sometimes not. BIG THANKS TO JWB AND MORTEN FOR TAKING TIME TO HELP ME. the dealer that has been working on it basically told me yesterday not to bring it back to them because they cant fix it.
