robert_kelly
Recently replaced the VRO pump and using 50:1 mix plus the VRO. The test tank has oil in the water. Is it from the crankcase exhaust or a leaking crankshaft bottom seal. The oil is black and sooty like exhaust. The outboard is 17 years used.
The lower unit has new prop shaft seals .
