Hi, I have a 93 6hp 2 stroke outboard on a 10' pvc dinghy typically used as a tender in salt water.
I ran it really hard all day a few weeks ago at WOT bouncing around the bay. On the last leg of the trip, it dropped power dramatically, like 50%.
The engine was still showing water streaming out the back but smelled really rich and stinky, like when an old car drives by running modern gas.
It runs great when cold, then gets warm and drops power. I pulled the t-stat out and it's pretty crusty so I ran it without one with no change. Both cylinders have spark and I have 110 lbs on compression in each cylinder. Does this engine have some sort of limp mode?
I am planning on swapping in a new water pump and t-stat but I am not sure what else to check.
