I have a 1990 Johnson 140 vro outboard that has been siting for 2 years. It was properly stored. Im having a hard time getting it running.
I replaced the following
- fuel pump
- compression is 125 psi
- new gas
- check all fuel lines no blockage
- cleaned out all carbs. They were very clean but I did it anyway
- new primer bulb
- Checked all vacuum hoses
- spark is great cleaned all grounds.
I had it running one day for a good amount of time then I’m not sure what happened. Not sure if I should try a regular fuel pump and delete the vro pump?
Help would be very appreciated thank you!
- fuel pump
- new gas
- new primer bulb
