The mention of "Spark Is Good" doesn't explain "How Good"!... The spark, with "all" spark plugs removed must jump a Air Gap of 7/16" inch with a strong wide blue lightning like flame... a real SNAP! Does it?
The cylinder numbers when standing in back of the engine, facing the spark plugs are as follows:
2....1
4....3
What are the actual psi compression readings of each individual cylinder? Your mention of questionable head gaskets raises a question in that area, but it's a specific that needs to be known regardless.
Air gap spark testers can be purchased at any automotive parts store... or you can easily build the following.
(Spark Tester - Home Made)
(J. Reeves)
You can use a medium size philips screwdriver (#2 I believe) inserted into the spark plug boot spring connector, then hold the screwdriver shank approximately 7/16" away from the block to check the spark or build the following:
A spark tester can be made with a piece of 1x4 or 1x6, drive a few finishing nails through it, then bend the pointed ends at a right angle. You can then adjust the gap by simply twisting the nail(s). Solder a spark plug wire to one which you can connect to the spark plug boots, and a ground wire of some kind to the other to connect to the powerhead somewhere. Use small alligator clips on the other end of the wires to connect to ground and to the spark plug connector that exists inside of the rubber plug boot.
Using the above, one could easily build a spark tester whereas they could connect 2, 4, 6, or 8 cylinders all at one time. The ground nail being straight up, the others being bent, aimed at the ground nail. A typical 4 cylinder tester follows:
..........X1..........X2
.................X..(grd)
..........X3..........X4
This can obviously be modified to a 6 or 8 cylinder setup tester.
