1991 70hp Johnson outboard
There’s no adjustment screws on these carbs
got the problem fixed thank you guys !
feel like an idiot was a simple fix my fuel line hose the filter I had put on it was starving my fuel pump/ motor so ran it without the trash filter ran like a champ lesson learned don’t buy cheap fuel filters!
Yea I did the same thing. Mine the hose clamp closed the opening. Plastic bent in. One other thought on rebuilding the carb
drill out the core plug and make sure the little holes just inside the throttle plate locations are open. Need it at idle.
They say you can never get enough help. Its up to you to decide what to do with it.
