Alright... I have replace waterpump kit numerous times over the years yet this time upon completion it barely pushes water? I ran wire thru orfices and taken the hose off all together and cleaned out where it goes into motor... still minimal water flow? Water isnt overly hot out telltale?? Kit was installed dry per manufactured recs as I have done in past... any ideas? Lastly,
I had some trouble laying on ground trying to reattach the finished L.U. back up and l ik ne everything up... after 20 minutes it finally all slipped together as it should and I bolted it shut. A short while later I noticed what appears to be L.H oil leaking out of the screen area and down the skeg? Could i have possibly damaged something putting the L.U. back on? I dont recall any seals or bushings etc. That I could have disturbed, but suddenly the screen is leaking gear oil? Lastly, assuming I have to pull lower and bearing carrier to replace all lower seals can any1 tell me what size length bolts and what threads to affix bearing removal tool into the two holes?
Any help is gr8ly appreciated thanks!
J.S.
J.S.
