bradvanbuuren
trying to locate the wire for my trim signal sending wiring to hook to my gauge any help would be great !
The trim wire IF it's there is usually taped back from the harness under the dash.
Where did the trim sender come from? Was it there from the factory?
Can you post a pic?(you need to have 5 posts before you can post)
The reason I ask is you don't see many if any on Forces.
