whitegreg56
The club inherited this E25TELEIE quite some time ago.
It was converted to a remote control and steering wheel before we got it.
The engine is running perfectly in forward and reverse at any throttle opening.
It has always been somewhat difficult to shift into forward and reverse but after replacing
the control cables with new Teleflex 479 cables and having the gearcase removed for water
pump replacement, it is worse. Local dealer said the remote control is going bad, so I replaced
that with the same single lever control 174228 that I found on ebay. Still has the problem.
It is very apparent that the reason it is difficult to shift is that the control needs to move
the cable about another 1/8 inch before it is done going into gear and starts opening the throttle.
The shift lever on the starboard side of the engine does not go any further! Forward or reverse.
So, what is holding things back? Wrong control? Wrong cables? Wrong shift lever? Problem with the gear case? Some adjustment?
I'm wondering whether in the conversion from tiller to remote the wrong parts were used.
All that's needed is another 1/8 inch...just can't figure out how to get it!
