I have a 1990 Mercury 4hp and need to replace the impeller.
After removing the two bolts from the lower unit I try to remove the lower unit, the gear shift is in neutral to start out as the lower unit is moved the gear shift goes into reverse and the then lower unit stops (~three inches) just enough to see the impeller. I tried moving the shifter into reverse then move the lower unit off but stops about three inches and will not come off any further. Tugging does not help or giggling the gear shift. Any ideas?
I seen video and theirs come right off with no issues.
Thnx
Marty
Thnx
Marty
