1990 evinrude warning buzzer
romex
"for some reason when i run th
"for some reason when i run the motor above 3800 rpm's i get a warning buzz , it it not constant.When i bring the motor back to 37 the buzzer stops.tHe VRO is plugged off and pre-mix is in the tank. any Ideas ?"
"if this is a V-6,i would susp
"if this is a V-6,i would suspect a fuel restriction/overheat...any other size i would suspect its time for a new water pump.Are the VRO wires disconnected from the VRO pump?"
