badtomatoes
Took my new (to me) boat out for the second time today. The engine started right up, though it did run quite smoky for a few minutes. Took it out and it seemed to run "okay" but seems great at full throttle. Ran about 2-3 miles, shut it down to fish for about 20 minutes. She started instantly with a touch of the key, then died flat, seemed like an electical or ignition type of failure because when it would die, it would do it immediately. Tried to stary with no luck for about 20 minutes. Finally got it going again and it seemed that I would have to start it, let it idle for a minute or two, only then would I get into the throttle. Maybe it was just paranoia and/or fear, but that's how I kept it going. It did the start the die thing once or twice again after, usually when I would put it into gear. If I tried to re-crank from the ignition "on" position, it just cranked with no fire. When I would first turn the ignition switch to the off position before cranking, it seemed to want to fire. Could be overthinking this part though. The engine seems to have an okay, though not great idle quality, but i dont know how smooth I should expect from a 1990 2 stroke engine. When I am accelerating at part throttle, the engine seems to run rough, almost like it is "loading up", not quite sure if it's a miss. When it's fully open, the engine is smooth and strong. Does this sound like a familiar problem to anyone?
Part of my issue is just not knowing what is "normal" or characteristic operation. I dont know if what I think might be rough or poor running might be considered acceptable for a 20 plus year old outboard.
Im an automotive guy and have all the tools I might need. From here I pan to do a few things. Please critique my game plan if you feel the need:
Replace the NGK with the factory recommended plugs (I think Champion) and inspect for irregularities.
Visually inspect all ignition components
Check resistance of ignition coils, charge coil, sensor coil
Perform compression test
After that- sync and link?
Carb rebuilds?
Thanks in advance for any helpful feedback!
Carb rebuilds?
