I bought the boat a few weeks ago it set for about 3 years I did the water pump cause the pump was stiff thought that was it but no pulled the thermostat it had busted I pulled the chunks out so I pulled the whole motor apart nothing blocked hope it is the bucket
Install a new thermostat. It creates back-pressure needed to have the water telltale function properly.
Clean the plastic telltale fitting with a piece of wire.
Drop the lower unit, dismantle the water pump for inspection.
Don't try to guess-work the engine... there are water passages... there are no ports or valves!
Vics, the 9.9 suffers from the exact same problem. I chased cooling issues on my 1979 Evinrude 9.9 for over a year. Water pump, thermostat, telltale, align water tube.....I did all the usual stuff. Then, JoeReeves mentioned the grommet at the base of the engine. When I tore mine apart I found the grommet was swollen and distorted to the point that the opening was barely the diameter of a pencil lead.+1 regarding the grommet at the top of the water tube ....
The 9.9 is not exactly the same but may still suffer from the same problem.
