1990 40hp evinrude alarm went off
Joel Kiss
I pulled into the my boat slip after about 15 minutes of running the engine and the alarm sounded the water guage hadn't moved either
There are three (3) different horn warnings... you don't say which one you encountered.
Beep every other second = VRO failure (no oil)
Beep every 20 or 40 seconds = Oil tank down to 1/4 tank level.
Beep constant and steady = Overheating
I'll assume overheating.... either your lower unit grabbed onto a plastic bag or something to restrict the water flow temporarily OR the water pump is failing.
