"I had trouble tonight startin
"I had trouble tonight starting my 1990 40 hp with electric start. I had it running last weekend for the first time this season, when it started kind of hard, but it ran OK once it started. (I'm using fresh fuel in a clean tank.)
Tonight it started reluctantly after many cranks, then died within a few seconds. I found I could keep it running by pumping the ignition key (primer solenoid). It dies when I stop pumping the key. This leads me to think I'm not getting enough fuel.
I pulled the hose off the fuel pump outlet and there appears to be a pretty strong fuel flow when I crank the starter. (I'm not sure how much is enough.)
The Clymer book says to "check the primer solenoid by depressing the primer while running the engine at 2,000 rpm and looking for about a 1,000 rpm drop as the mix goes rich." But I can't keep the engine running well enough to tell anything. I think the solenoid is located on the starboad side of the engine, but am not 100% sure. It looks like there are 3 small hoses coming off the the fuel pump, one goes to each carburetor, the other seems to go to the primer solenoid and I had a hard time telling where from there. I'll check the resistance of the primer solenoid coil in the morning when I have some light to see what I'm doing. It's supposed to be 4-7 ohms between the purple/white lead and the black lead.
I would really appreciate if someone can provide additional troubleshooting advice or explain how the solenoid is supposed to work.
Striped bass are running in the bay and I'm anxious to get on the water.
Thanks!
Chuck"
Thanks!
Chuck"
