I have a 1990 175 Hp evinrude. I just recently purchased the boat. The previous owner said he hadn't ran it in a couple of years. I have completely drained the tank and replace fuel. I have completely rebuilt the carbs and replaced the spark plugs. This seemed to definitely improve the performance of the engine, but, I still at times have to choke a hot motor or use starter fluid to get the engine to start. It has no problem with firing. In fact usually when it will not start, it will fire once but not start. It has very little power. When not in gear it will crank to 7 or 8k rpms, If in gear and the boat is trimmed out, the best you can get is 3800 and 25 mph. It DRINKS gas. About a gallon per mile travelled. Would the timing be an issue, and if so, how do I check it???
