1989 Mariner 40Hp how to disable oil injection
rcb13
Hello All. This should really be a question for racerone.
Please provide detailed instructions on how to properly disable the oil injection system on the above motor. It is a 6E9-L-450120.
rcb13
Is it a gear driven system or a unit called ---" autoblend " on this motor ?---------On gear driven units you can re-arrange the hoses.--------------Take pump discharge and return that oil to the tank / intake side of the pump.------------------------It would then be easy to put system back in service.
I will have to look at motor tomorrow. It is not at my location. I will respond with requested information.
rcb13
racerone,
It appears to be a gear driven system. oil tank has two connections on lower aft end that are connected to each other by a loop. On the bottom of the tank is a electrical connection and a hose going to the pump. The pump appears to have two outlets, each outlet feeding into the carbs next to the intake manifold. How do I disable this type and what are the new hose routings?
rcb13
attached (I hope) are pictures of mariner oil injection cowl.
rcb13
Faztbullet,
Look at Mariner parts on Marine engine's site for 6E9-L-450120 under "search by horsepower,model number,etc". 40Hp twin carb with oil injection is the one you want to look at. Shows the oil pump arrangement.
rcb13
First one I have ever seen and worked at Mariner dealer!!!! We sold them(40') on Dynatrack 160's with TM,6gallon tank,Autoblend turn key ready for $7995 and $99 a month. Sold 35+ at first at show...!!! :)
