Good afternoon, is it best to leave the Trim/Tilt reservoir plug (screw) "in'" or "out" when filing it up. I've seen videos where folks say to do both ways. I see that leaving it out and cycling the motor up/down where fluid runs out, but that guy says it helps air escape and then once you stop hearing that gurgling/screeching noise (indicative of trapped air, correct?) to fill one last time until it's full (fluid running out) and then put the screw back in. I submitted a post a while back and it was agreed by post responders to fill with fluid, put screw back in and cycle motor down then up and repeat process several times until I can't add anymore fluid. Yes, I understand the leaving the screw out and cycling will cause fluid to run out of the open filling hole. As always, thanks for your input.
Jack
Jack
