B
BRSBOATER
Guest
"I am about to go crazy..Compr
"I am about to go crazy..Compression is 105/110 on cylinders. I have rebuilt the carb..It will start right up and run but when I go to give it gas for high speed it will run for a while then shut down..if I press the chock button it will run for a while..if i keep doing that at mid speed it will keep running....I put a new carb kit on..new needle, new float, new gaskets..blew it all out with air hose...put new sparks plugs in....I have changed the position of the float about ten times..last time was burning to rich..gas was comming out the carb. Thank You for your Help/Suggestions Brian"
