DeluxeRapala
Hay y’all on here noobie here,
just picked up this 89 Johnson 25hp outboard
electric start and remote steering long shaft for $300
120 psi on both cylinders and runs dumping some fuel down the carb.
so here’s the thing,
everything I’ve read so far states the engine should have been sold with a primer enicherner and not a physical choke valve and solenoid.
well it has both???
so the choke assembly works minus the solenoid no click with the key or when I put power to the solenoid
but it also has the auto enricherner, wires are not hooked up but the gas lines are.
pictures that I’ve seen of 89s don’t have a choke just the auto primer
what is the correct set up? Doesn’t appear to have room for both I am assuming someone put a older carb with choke on it , and I just need to replace the auto choke plunger solenoid
well it has both???
