Look close at the intermediate jet on thefront of the carb you may need to fab up a screwdriver to fit the hole they are in pretty tight. I have the sneaking suspition it has been reamed out. What elevation are you running the engine?
Be careful when you decide to " re-engineer " this stuff or make changes !!
I just found a 25hp carb with the screens there what size is the high speed jet in the float bowl? Possibly someone wanted to gain some ponies. They are probably for the bowl vent?
Yep, saw it and I agree.See post # 31
Ah ok... good. Thanks!Lots of times.-----Do not have enuff fingers and toes to keep track of how many times !
It looks like they used that design in the late 80s early 90s and went to the flat top. That engine had the same displacement in 20-25-28 and 30hp. I am not a big fan on the carbs with both a slow needle and a intermediate air jet. Mid to late 80s had the slow needle on the front of the and easier to dial in IMO.
You should be fine just replace the parts in the kit you take off of that carb. Float needle and seat, gaskets, soft plug. I always pull the jets and blast everything good with hogh pressure water to scour the circuits. Make sure the float is level and square and never put fonger pressure on the float pull it and then check it with the weight of the float only. The gasket in the center pf the float bowl is the most common item forgot FYI.
Ah ok cool. I think I have a nozzle reductor somewhere, that should do it to build up some pressure... thanks againI use the garden hose we have around 90 psi here.
The fuel in the bowl needs atmospheric pressure on it-----Therefor all carburetors are vented.
Take a good look and see if there is a passage way that had to be drilled.---Then access is plugged.----Your investigation is leading you nowhere !
The one that is plugged is actually air for the high speed emultion tube the brass tube center of the float bowl going up to the nozzle. It helps the fuel atomize before entering the venturi. The little holes on the side of the tube basically causes the fuel mix to bubble as it is sucked from the float bowl.
I'm saying is the carb body was designed, and molded with TWO air vents leading to the bowl, but one is supposed to be plugged.
Understood, thanks.That core plug is sealing the drilled hole that serves for a fuel passageway.
k, thanksIf you have one that fits in the kit yes.
