Is this tested cranking or running?
Pull the top org/bl coil primary and swap it to bottom coil...if it fires coil is good. The check timer base by swapping inputs from it to pack, it problem goes to other side timer base bad.
No difference still cylinder #6 not getting spark.... looks like power pack ya think?I will try that this morning... thanks
I have used this method many times if it sparks on the opposite bank after changing the firing order and the problem is still on the same cylinder then change the power pack providing you have confirmed its not the ignition coil.
Sometimes it's just that one of the pin/socket connectors within those rubber connectors... the action of pulling apart and pushing together results in either the pin or the socket backing out just enough to make a poor connection between the timer base and the powerpack or between the pack and the coils.
Also, I've come across a few cases where the wire actually broke free of the pin/socket and was held in the rubber connection by pure friction.... perhaps not your problem but something worth looking at.
It appears that all pins/wires are connected properly.
I would have the battery load tested.-----I would take the starter apart for inspection.-----Look at the flywheel magnets.-----Note these are easy steps and cost very little coins to do !
